Miss info on TH200C
Did'nt want to put this into the Transmission section because it really is opinion. But I would like to point out in a direct quote from DRW Transmissions on how the 200C has gotten a bad rap over time and point out some of the flaws of the TH350 that die hard 350 users just dont seem to admit too.
[I]"A little history on the THM 200 and 200C. The 200 was introduced in 1976 as a more efficient 3 speed automatic as compared to earlier design 3 speed automatics such as the THM 350 and THM 400. The need for this new automatic was brought about by the gas crunch that came about in the 1970s. The 200 was produced from 1976 through 1978. This unit used an open style torque converter (non-lockup). The 200C unit was introduced in 1979 and used a lockup torque converter clutch to further increase vehicle gas mileage. The early designs of lockup torque converters gave the 200C a very bad rap since most of the failures were brought about by the torque converter. Having built many 200s and 200Cs during the 1980s, I had grown a respect for the unit. It was simple, quick to rebuild and when done correctly was very reliable. Of course, we always crossed our fingers when it came to the torque converters, but GM eventually straightened out the design problems of the early lockup torque converters and from that point on lockup torque converters took over the industry. The 200 was the first to introduce a radical design change in the hydraulic control systems that has carried on to all future designs for GM. This was probably a very big factor when it came to the acceptance of this new unit by transmission technicians that struggled with trying to understand why they couldn't get these units to operate correctly.
After performing some research and development work on the 200C for use as a high performance transmission, I have become very optimistic about this unit. It is light, simple, efficient, periodic maintenance or checkups can be performed very quickly and cost is low, although some very specialized recalibration has to be done to the unit to insure that line pressures are sufficient for high horsepower levels. Lets take a look at the THM350 and THM400 for a moment. The main weak points of the THM400 and THM350 transmissions are the intermediate (2nd gear) roller clutches or sprag as in the case of the 400. The case lugs that support the intermediate clutch pack retaining snap ring is another weak point for the THM400. Not to say that the 400 and 350 are weak by any means, but every transmission has its Achilles heel. During the course of a racing campaign the cost for periodic repairs is something that should always be looked at. The 200C uses a band instead of clutch packs for second gear as is the case for the 350 and 400 and this feature gets around the problem of catastrophic 2nd gear failure which eventually catches up to the 350 and 400 due to simple metal fatigue brought about by the stresses of racing. The bad part about the 400 is when those aluminum snap ring case lugs break, there goes the case. Not a cheap prospect. Those people that drag race their car and use the 200-4R as is the case with the Buick Grand National or Turbo TA vehicles usually do not use overdrive during the 1/4 mile run and since the major weak points for the 200-4R are in the overdrive section even after upgrading to a billet intermediate shaft, the 200C becomes a nice alternative for racing purposes while being able to save the overdrive transmission for street use between racing events. The main advantages of the 200C over other transmission model options are less rotating mass, lighter weight (96 lbs. 1 pound less than an aluminum powerglide) and most importantly less parasitic horsepower loss. Weight comparisons of common transmissions. With the two units on a bench, just the difference in turning effort by hand of the input and output shafts is amazing and very profound. This can't help but translate to less horsepower loss through the transmission and more getting to the rear wheels. I'm working on an auxiliary valve body that will allow electrically controlled shift points and a transbrake. Preliminary hydraulic circuitry studies show that the transbrake and electrical shifting will be possible with the manual shifter being left in the drive position. No need to fool with the shifter. The level of horsepower that this unit will be able to put up with is still to be determined, but I'm going to estimate 650-750 HP. Testing to follow and more info to come soon.
We have developed a TCC bore plug that will allow the use of a non-lockup torque converter with a 200C. The plug will allow a normal flow pattern into and out of the torque converter that is more traditional for a regular open type (non-lockup) torque converter."/[I]
