missfire - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2002, 06:02 PM
Post missfire
I Have 2000 yukon 5.3 vortec,it missfires but want give ck engine lite .so it want store it in the commputer. what do i look for?
Old 10-08-2002, 06:14 PM
Post
A spark plug. Had a new one go away in three days last month on a Contour. Truly maddening.
Old 10-08-2002, 06:59 PM
Post
Thanks Slider for the info i will give it a try
Old 10-08-2002, 08:40 PM
Post
Had an Impalla at work the other day with the same prob. Cleaned fuel injectors and it was fine. Like you said no check engine light. Also check your fuel pressure regulator
Old 10-08-2002, 09:13 PM
Post
just because the check engine light isn't on doesn't mean it isn't tripping codes. go by an autozone and they will hook it up to a computer and check it for free. if that doesn't work, change your plugs,your air filter, your fuel filter and run a bottle of injector cleaner through it. always change the cheapest things first because your car probably needed it anyways.
