missing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2005, 03:36 PM
New Member
missing
I have always have a small mis at about 4000 revs with twin 465 tunnel ram and is still there,if i put accelerator down smoothly it doesnt happens it pull to 6200 with no problem it only happens if i nail it ,?????
Old 07-17-2005, 06:26 PM
poncho62's Avatar
Wiki Edits: 5
Miss or hesitation (bog)?
Old 07-17-2005, 10:24 PM
New Member
hi it is i miss i have have no hesitation at all .To stop hesitation off the line we have set the accelerate pump with the throttle wide open this stopped bogging
Old 07-18-2005, 06:18 AM
poncho62's Avatar
Wiki Edits: 5
What are you using for ignition?
Old 07-18-2005, 07:45 AM
If it only happens when you nail it I'd have to say there's probably a lean stumble when the secondaries are opening. If this is the case you could try raising the fuel level inthe secondary fuel bowls for a faster fuel flow to the boosters.
If it's a lean stumble at a steady 4000rpm cruize this would mean the jetting needs to be upped a couple sizes. What powervalves are you running? What's the total engine parts combo? Are these vacume secondary carbs? Bob
GM 10 bolt diffy "S" spring missing? paulo Transmission - Rearend 5 04-18-2005 05:47 PM
missing part - TH350 darom Transmission - Rearend 5 10-19-2004 08:59 AM
Car missing while on Dyno? FBody Engine 11 09-07-2004 10:17 AM
Missing Members SkyMan9600 Hotrodders' Lounge 7 07-22-2004 09:56 PM
350 missing u000564 Engine 9 07-27-2002 09:15 AM
