Missing as in never installed? You might be able to use nutserts to do the job they are usually found at fastener supply stores.
http://www.aboveboardelectronics.com...nd/nutsert.htm I think a similar item is called rivnuts. They go in something like a pop rivit. If you go the drill the hole and use the socket through the hole route I would suggest drilling a pilot hole from the inside and then using a hole saw just large enough to get the socket through the hole from the bottom. It will make for a clean job and you can use a rubber plug to plug the hole. Watch for wires and lines of course. |
Thanks for the "nutsert" info- that may come in handy.
I believe cutting a hole through the bottom of the inner rocker area to get to the cab floor would be the only way to go. The receptacles appear to have been knocked off by the previous owner.... Why? I haven't a clue. Anyway- thanks for the input. After some consideration, I may just end up tossing the jumpseats and fabbing up some speaker boxes to take their place. Might as well- it's not like anyone's gonna be sitting back there anyways. Thanks again, Chopt~ Nooj |
Were there some sort of brackets or something that are missing? Most seats would have brackets that the nuts or studs were mounted to. As long as your seats don't have integral seat belts the nutserts are a good way to go. I have been using them for years in fabing and they are the cats meow.
If they have seat belts built into them, DO IT RIGHT and get the original set up from another truck. DON'T PLAY GAMES with seat belts. Brian |
Thanks for the replies-
I have all the brackets and all. It's the "nuts" (for lack of a better word) mounted underneath the cab that the brackets bolt into that are missing. So, all I have is a hole in my floor, with no receptacle beneath it. The jump seats do have integrated seat belts- but I believe I'm going to try my hand at some mdf/fiberglass fabrication and do some speaker enclosures instead of using the jump seats. I originally wanted to use them because I got an all matching interior from a donor vehicle, and I wanted it to look complete. Thanks for the input. After looking at those nutserts again, I may just give them a try... I'm sure I'll find some kind of use for them- if not with this application ![]() Nooj |
| missing bolt receptacles | lumberjacknooj | Body - Exterior | 0 | 04-09-2007 08:58 AM |
| Cab dolly for 47-54 chevy truck | sevt_chevelle | Body - Exterior | 2 | 06-19-2006 08:27 AM |
| hey do i need to brase the cab of my short cab pic up befor lifting it off my frame | mopar_101 | Body - Exterior | 7 | 07-19-2004 06:28 PM |
| 86 s-10 vibration cab mounts bad? | catscan4free | Body - Exterior | 4 | 01-26-2004 03:23 AM |
