missing fitting - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2009, 07:16 PM
missing fitting
I got this '49 Ford F-5 Cab-over- truck, fixing the brakes, .....was taken apart by the former owner a couple years ago, and I seem to have lost some parts.... I need to know what kind of fitting goes on the master cylinder ? Now it has 3 lines near the end of the M C , all 1/4'' inverted flare ends, and all postioned VERY close to the M C . So, I'm thinking some kind of 4 way fitting ???????? also where does the stop lite switch go ? I assume it had one....
Old 12-18-2009, 12:26 PM
amx180mph's Avatar
Cunningham and Hersh Hot Rods
You should have a 5 way brass splitter that goes in the aft end of the master cylinder. This is where the brake light switch goes along with our 3 lines.. If you need one I think joblotauto.com has them.
Dale
Cunningham & Hersh Hot Rods
Old 12-20-2009, 10:27 AM
a 5-way fitting....that would make sense....had to imagine I could misplace something like that, I'll look it up...thanks
Push-in style air fitting leaks on air suspension shad9876 Suspension - Brakes - Steering 10 02-18-2009 07:24 PM
flare to flare elbow fitting GMR Hotrodding Basics 0 07-16-2008 08:14 PM
trans cooler fittings.. 3/8 hose fitting to a AN fitting? scapegoat Transmission - Rearend 6 04-14-2008 05:12 PM
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 10:33 AM
water pump fitting leaking brian400ex Engine 4 03-22-2003 06:06 AM
