missing holes in oil filter?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2012, 02:31 PM
Gearhead forever's Avatar
I couldn't find a Fram PB50 filter so I picked up the Carquest crossover unit. I cannot see for the life of me how this is supposed to pass an adequate amount of oil - it looks as if someone forgot to punch the holes!
Old 01-15-2012, 03:48 PM
zbhover's Avatar
V8 Beetle & Hovercrafts
Yeah I'd say they forgot a step when they were making it............. Scary to think how many might be out there like that and how many people wouldn't pay any attention and not noticed it.
I'd say throw out both the fram and carquest filters and start buying better brand filters......... I personally prefer Wix, or AC Delco (if I'm working on one of my GM's)
It's been said that fram quality has gone down hill, I know I've personally seen fram air filters with rubber "flash" covering 3/4 of the air filter, and have herd lots of bad things about their oil filters, but have never used them.
ZachB
V8 Beetle Site:
v8beetleresource.com
Hovercraft Site:
zbcreations.com
Old 01-15-2012, 04:30 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
I sure wouldnt use it
Old 01-17-2012, 07:43 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Mounts
Downhill from where, or when?
They've been garbage for as long as I've been in the parts biz. (1979)
The last PH8A cutaway that I saw was actually an "improvement" over the 1979 version. AT LEAST the pleats now had a metal cleat installed at the media joint. The media was simply overlapped a few folds and glued to cardboard end caps on the '79 vintage.
I seriously want to crawl under John Forces funny car and check what he uses on his. (Orange paint on a Wix?) LOL
Edit:
BTW ... that filter is not "missing holes".
It's designed to flow 1-3 GPM
Part Number: 1050
UPC Number: 765809135840
Principal Application: Allis-Chalmers, Fiat, Continental, GM, Hyster, Isuzu, Iveco, Towmotor, Other
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: By-Pass
Media: Paper
Height: 5.178
Outer Diameter Top: 3.660
Outer Diameter Bottom: Closed
Thread Size: 5/8-18
By-Pass Valve Setting-PSI: None
Burst Pressure-PSI: 380
Max Flow Rate: 1-3 GPM
Nominal Micron Rating: 10
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Old 01-17-2012, 08:14 PM
Wiki Edits: 31
Yep, and Carquest is WIX/ Affinia
Cometic head gaskets missing holes??? 10scnd70 Engine 3 05-22-2011 06:03 AM
Changing the filter in the FRAM HPG-1 fuel filter assembly tombguard Hotrodding Basics 3 08-18-2009 06:24 PM
Protecting screw holes or trim holes in body? ScotY Body - Exterior 6 01-29-2009 01:37 PM
where the fuel filter and help with missing tsw5013 Engine 10 03-02-2006 08:23 AM
Filling up holes in body, including rust holes Mr.56Chevy Body - Exterior 5 12-12-2002 11:55 AM
