Missing TCC Connector - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2008, 08:02 PM
I need your help! I have a 1990 Chevy 1500 2wd Step side that I purchased 2 months ago. The previous owner took out the original 700r4 and replaced it with a 350 turbo with a 9 inch long tail. That trans was shot at the time of purchase and would only go in reverse. I have decided to put a 700r4 back in the truck that came from a 1990 Camaro, but I have one problem. The TCC Connector was cut off and discarded during the trans swap. The wires are still there but the connector is missing. I am in need of the connector that plugs into the trans and a diagram tat shows me how to connect it. If anyone can be of assistance I would be greatly appreciative.
Thanks,
Lance
Old 06-07-2008, 08:07 PM
Wiki Edits: 31
GM can get you the connector if you go to the parts counter of a Chevy dealership
Old 06-07-2008, 08:18 PM
Thanks for the reply. I went to the GM Dealership yesterday and they informed me that they no longer make the connector. They only have the part that is in the trans not the part that plugs into the trans.
Old 06-07-2008, 08:27 PM
Wiki Edits: 31
A junkyard would have it, if you can't find it elsewhere.. you could call Dons automotive mall in Binghamton Ny, he ships everywhere and probably has it
Dons Auto Mall
Binghamton NY : 1-800-283-3667
www.donsauto.com
Old 06-07-2008, 08:30 PM
MissingTCC Connector
Thanks again. I will give them a call tomorrow. I will let you know what Happens.
Thanks,
Lance
Old 06-08-2008, 12:55 AM
SSedan64's Avatar
Plug should be marked with very small letters A=top left, B=top right, C=bottom right, D=bottom left.
A=12Volts feed from brake or toggle switch,...........................................
B=4th gear switch ground to ECM- Computer Cars, ..................................
C=3rd gear switch ground to ECM- Computer Cars, ...................................
D=Computer feed ground to activate Lockup............................................
A=Purple usually........................................... ......................................
B=Light Blue usually........................................... .................................
C=Dk Green/White usually........................................... .........................
D=Tan/Black usually........................................... ................................
Some Trans have 1, 2, 3 or 4 wires depends on model, computerzied or no Com.
Old 06-08-2008, 08:03 AM
This info is extremely helpful and I really appreciate it. Once up and running I will post pics.
Thanks
Old 06-08-2008, 08:37 AM
As noted above, you can get the connector at a wrecking yard from pretty much any 700R4 or 200-4R trans from the 1980s. You can also buy the connector and pins new from Waytek Wire:
http://order.waytekwire.com/IMAGES/M...og/220_033.pdf
You want the 4-square connector.
Old 06-08-2008, 08:42 AM
I will look on Waytek Wire right now.
Thanks
Old 06-14-2008, 03:20 PM
700r4 Shifter Linkage.
You were all very helpful when I neeeded the TCC Connecter and now I have one more issue with the trans. I need a shifter linkage for a 1990 Chevy Stepside 2wd automatic with a 700r4 trans. I dont know what this part looks like or where to get one for my vehicle. Can any of you be of assistance. My truck has been sitting for over 1 month and it has come down to this in order to get it on the road. Any help will be greatly appreciated.
Old 06-15-2008, 01:49 AM
SSedan64's Avatar
Unless your using a aftermarket floor shifter you're going to have to get the column shifter linkage from the junkyard or Aftermarket company like Shiftworks.com, Lokar etc. May check EBay, search for shift or 700R4 shifter linkage.
Old 06-15-2008, 05:42 AM
Shifter Linkage
Very helpful thanks!
Wiring a CS Alternator swap with only a 1 wire connector? Cousin_Joe Electrical 4 05-07-2008 02:05 PM
weather pack connector help keywestjack Electrical 1 10-28-2007 02:28 PM
700r4 is fluid routed to cooler when TCC is off eliotmansfield Transmission - Rearend 3 02-12-2006 06:56 PM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
Car missing while on Dyno? FBody Engine 11 09-07-2004 10:17 AM
