Does anyone know for sure how long DuPont's Chromabase will
last after mixing with their basemaker?
Can I store the mixed product for a few days and use it later?
It doesn't look to me like it's going bad.
JC, Good timing on that question as I was just thinking about asking the same thing yesterday when I threw away some silver Chroma Base that I will not need for a few days. I have enough unmixed to finish the job, a spoiler that has not arrived yet, but if I could have saved that for a couple of days I could have kept the fresh paint for possible later use.
The exception to the rule IF there is one, (I'm not sure)
would be the Dupont because of the basemaker that is used instead of
urethane reducer. The Dupont basemaker is different than the Sherwin Williams and I don't know if it has a shelf life or not.
See Jim if I could get you to let go of that Dupont stuff you could store PPG until they change the paint systems again... Kinda like I know you still have some laquer and AE stuff you just wont let go to the wayside... You know what they say about old dogs imp:
Years ago had a friend as enamel was bitting the dust, took all the factory pack gallons in his store and mixed colors and rolled it on every wall inside his house. Like he said it will be forever!
Oh, they did have to move out for about 3-4 weeks because of smell.
He saved a lot of money Jim!
Am I bad for still having a gallon of lacquer from early 90's. Dealership I was working for was getting rid of all the Dupont lacquer on the banks and told me to dump it all, and I took a bunch of different colors, mostly the silvers, and threw them together in a gallon can, and kept it. Never used it and still have it. I still have a little bit of ppg grey green dp also that is many years old, but know that has chunks in it and I'll pitch it. Hard throwing money away isn't it. Got a little under 2 quarts of corvette grey dbu base, about 15 years old. That should still be good. The reactive reducer for it is toast though.
If you add hardener to the paint, I suggest you use the cheap disposable rollers for cleanup issues. I also suggest a short nap roller for the smoothest most even coats possible. Paint tech instructor taught me well. Or did you guys forget about him.
Somehow I guess I assumed that the Dupont base had a short shelf life after mixing with Basemaker so I tossed about a pint of it thinking it would not keep for a week, but what the #&^% it's only about $300 a gallon
I asked my Dupont guy today and he said it will last a LOOOOOOOG time as long as the can's sealed good.
I can't believe you guy's are "rubbing the genie lamp"
He was a laugh but I don't miss him.Well,Maybe a little.
It was a kick trying to figure out exactly what he was typing.
jc was about the only member who could speak Paint Techbonics.
jc, You got a crack pipe hid out in the shop someplace? :mwink:
No, I don't need one. I get to smell all the paint I want :thumbup:
That crackpipe might be a good "tip of the day"
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
