Mixed tire sizes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2013, 05:23 PM
bigdog7373's Avatar
Of course it's fast
Mixed tire sizes?
I have a half worn 195-60-15 on the left and a little less than half worn 185-65-15 on the right side of my back axle. It was like this when i got the car and it drives fine. But i just want to make sure its cool to leave it alone. I looked up the diameters of each and they are .2” difference if diameter is both were new. Thanks in advance.
Old 07-19-2013, 06:45 PM
Banned
you may think it is fine the bigger side is putting stress on everything. failure is on it's way.
Old 07-19-2013, 07:26 PM
bigdog7373's Avatar
Of course it's fast
Alright that's what i thought. i'll get it changed out tomorrow, thanks
Old 07-20-2013, 01:52 PM
You didn't say what type of vehicle, which could make a significant difference. If its FWD the rear wheels are just along for the ride and there is no real stress. If its RWD you might have some differential components working harder to compensate for the .2" difference. However, it will take a long time for it to cause enough stress to get worried about.
Put the tire replacement on your list of fixes, but its not something that has to be done ASAP unless you have ABS brake sensors or traction control that would be affected and cause a safety issue.
Bruce
Old 07-20-2013, 03:10 PM
bigdog7373's Avatar
Of course it's fast
Its rwd. I just put two matching tires on it so i'm good now. The smaller looks like it was skipping to keep up with the larger one cause it's way more worn out. Good thing i changed them, the belts were starting to show
Tire Sizes joeford Hotrodding Basics 2 11-23-2007 06:02 PM
Tire sizes!?!? 87442lover Engine 4 10-18-2004 01:33 AM
i need some help with tire sizes digitalfrek Body - Exterior 6 07-19-2004 02:42 PM
tire sizes CARGUY Suspension - Brakes - Steering 1 03-14-2003 09:28 AM
HELP!!! with tire sizes and such. i got a few ?s tony350ss Suspension - Brakes - Steering 2 10-26-2002 03:56 PM
