Mixed up pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2013, 11:28 AM
Mixed up pistons
I had a 454 disassembled and was going to freshen up with new bearings rings and so on.
Problem is that during a recent move, the rods with pistons still attached were packed in a box and taken out of the order I had them in. Now I do not know what piston belongs to which cylinder.
What do I do now?
Old 04-29-2013, 12:57 PM
techinspector1's Avatar
Wiki Edits: 326
If you plan to hone the cylinders lightly for new rings, it won't matter much which piston goes back into which cylinder. Just pay attention to the mark on the piston crown and point it to the front of the block. The chamfer on the rod big ends goes to the counterweight side of the rod journal, not the middle of the journal.
Old 04-29-2013, 04:34 PM
BOBCRMAN@aol.com's Avatar
Usually, but not always, the rod will be numbered. That way the piston will end up in the correct hole.
mixed up some pistons and cylinders One to Remember Hotrodding Basics 29 11-27-2011 12:03 AM
Mixed tires? Slipangle Suspension - Brakes - Steering 3 08-15-2006 11:43 PM
mixed up truck jackodom Introduce Yourself 3 04-23-2006 09:45 PM
mixed up pickup.....! westdream Introduce Yourself 1 09-12-2004 10:53 PM
Mixed up valves. meschnebly Engine 4 10-07-2003 07:55 AM
