mixes marine gas and regular pump gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2010, 08:40 PM
The mobile view is crap
I am wondering about mixing gases. Is there a difference between marine gas and regular pump gas. If the two are mixed will there be any consequences?
Old 08-18-2010, 08:45 PM
ericnova72's Avatar
More for Less Racer
Mix all you want, they are compatable. No advantage to it however, the marine just costs you more for the "privilege" of buying it at the Marina.
Old 08-18-2010, 09:19 PM
BOBCRMAN@aol.com's Avatar
Marina actually pays less for gas as the "road" taxes are not on it..
Old 08-19-2010, 06:31 AM
Wiki Edits: 31
yea, theres no road tax but it's usually at least 50 cents more per gallon at the pumps on the water
Old 08-19-2010, 07:30 AM
Marine gas typically (at least it does here on the Chesapeake Bay of VA)has little or no ethanol because boats typically sit more than they are run. The alcohol plays havoc when the gas sits very long.....(gathers water so bad)
gas prices 69novarodr Hotrodders' Lounge 27 04-17-2009 10:47 AM
Racing fuel or regular gas? 189fmc Engine 12 07-27-2008 08:01 AM
want cheaper gas prices?? plz read this sherfield2002 Hotrodders' Lounge 7 03-12-2004 06:22 AM
Mixing High Test & Regular Gas to Increase Octane acr Engine 6 12-30-2003 07:58 PM
