mixing atf
is it safe to mix two different types of atf?(such as dexitron2 and type f)
yes Dexron II or III and type F can be mixed.
they will not foam up , slip , turn to goo when mixed.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
After a little research, it appears that most all types of automatic transmission fluid can be replaced (or added) with Dexron (III) type fluid, EXCEPT TYPE F. Any info that I can find says DO NOT MIX TYPE F WITH ANY OF THE OTHER TYPES OF TRANSMISSION FLUID.
============ I have mixed these two for decades with no trouble. The type F will take on more properties of the dexron than the dexron becoming Type F. Since the removal of whale oil from dexron decades ago under federal and other laws mixing is not an issue. Under lab testing I read 10-15 years ago dexron held up better than type F. That may be different with modern blends
