Mixing bolts and studs on main caps - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2007, 11:42 AM
I am building a 383 SBC and have all the machine work complete and nearly all my new parts ready for assembly.
I am going to use a new Milodon stock oil pan and windage tray. I will need to either get an installation stud kit from Milodon (6 studs from Summit: http://store.summitracing.com/partde...0&autoview=sku) or get a full set of ARP studs with the windage tray provision in order to install the windage tray.
Do any of you experienced engine builders see any problem mixing studs and bolts on the main caps?
It seems logical to me that one should either go all studs or all bolts. I am concerned about possible different expansion rates and strengths.
This is just a high performance street engine going into a Street Rod ('36 Coupe) with a T-10. This engine will not see over 6 grand as it will be limited by a MSD 6AL.
If anyone has any knowledge about this I would appreciate reading your post, I just don't want to make a decision then have regrets.
Harley Monster
Old 12-31-2007, 12:57 PM
I just spoke to the machine shop that did my machining and they recommend all studs or all bolts because of the different torques involved.
Any other comments?
Harley Monster
Old 12-31-2007, 01:09 PM
Changing over to studs does create a small problem as there is more clamping force with a stud and sometimes it will change your housing bore size.
If we change over we automaticly line hone the blocks as it takes the guess work out later.
Old 12-31-2007, 03:28 PM
The block has already been align bored, but with the bolts, not the studs. Do you think that would make a difference?
Old 12-31-2007, 03:43 PM
I think it would change things but your machinist can measure before and after and make that decision.
Old 12-31-2007, 11:25 PM
Old does not mean dumb
If the mains are already honed, why not go to the Chevy parts counter and get six 1969 to 1976 Z-28/ LT-1 windage tray main bolts. Then you well not have to worry about the size..
Old 01-01-2008, 06:57 PM
Wiki Edits: 31
Chevrolet did just this factory on TBI 350 4 bolt engines cause of the windadge tray. they have 2 diffrent torque specs, 1 for the bolts and another for the studs
Old 01-01-2008, 08:39 PM
matt, do you have the years those engines were produced so I can find more information on them. Do you know the torque specs for the bolts vs the studs?
Harley Monster
Old 01-01-2008, 08:51 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
CNC, if the owner of the block brings in a set of to replace the inner bolts and uses bolts in the outer holes can you still line hone the mains accordingly?
What is most common when using splayed caps?
Old 01-01-2008, 08:55 PM
Wiki Edits: 31
Harley Monster
'87- 1995 are the same and all 4 bolt. I'm not sure but If I remember right, the studs are 65 and the bolts are 75... they use the studs in the center caps.
I don't have the torque spec, 65 and 75 is what I remember but any hayes or chiltions for a mid 90's Chevy truck will have this info. prolly available at a library
Old 01-02-2008, 08:08 AM
On splayed caps we buy them for Kenny at Program Engineering and we have to use studs down the center as the caps are the Nextel cup caps and are appox. 3/16 of inch taller then a stock cap so we have to use studs down the center and bolt on the outside.
The blocks are line bored for the new caps and finished with a line hone to size.
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 06:55 AM
re-using rod and main bolts? Blob Engine 22 10-21-2006 09:07 AM
Main Studs Not Long Enough Canadian Charlie Engine 5 02-09-2006 12:25 PM
Bolts & Studs... NXS Hotrodders' Lounge 5 01-25-2006 09:14 PM
Main caps - studs or bolts? camaro80 Engine 6 02-06-2005 12:16 PM
