mixing paint ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-04-2007, 07:37 AM
Vortech 4.3's Avatar
jack of all trades
mixing paint ?
i have PPG acrylic enamel. since i am broke, that is what i am going to use.
but i forgot what ratio to mix the paint, reducer and activator.
also, about how much would i need to do an s10 hood ?
please help, thanx.
Old 07-04-2007, 07:42 AM
jack of all trades
also. since i am going to do the underside of the hood first. it has a lot of areas where i need to get under the cross brasing. so i was going to shoot through the holes and around the brasing first. then a final even coat. is there a rule of how long i should wait for the first shoot to dry, before the final top coat ? then how long for it to dry before i can flip the hood over and do the top side ?
i would do both sides at the same time. but i want to practice on the underside. and i don't know how well that will turn out.
thanx
Old 07-04-2007, 12:44 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
well, you gotta try to find the tech sheet with the right directions how to mix the paint.
i would agree doing the bottom of the hood is a better idea to do first...and once again, id check the tech sheet for your paint because it will have the correct flash times....you could always just wait a real long time and could be pretty sure it was dried fully....but id find the tech sheet either way.
Old 07-07-2007, 05:12 AM
jack of all trades
i don't even remember if i got a spec sheet, when i bought the stuff. i guess i'll just call the place i got it from. thanx.
Old 07-08-2007, 08:14 AM
mix
I beleive its 4:1:1,all tho im not 100% and I would give each coat at least 15 min. to flash
The paint did not harden powerrodsmike Body - Exterior 27 03-05-2009 05:34 PM
Paint Question #157 rj57 Body - Exterior 5 10-31-2007 02:20 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Basic of Basics - Choosing a color Centerline Body - Exterior 1 11-26-2005 09:12 PM
