MMM doing away with Hookit II - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2010, 09:27 AM
cyclopsblown34's Avatar
Colorsanding painter
I just found out today MMM is doing away with Hookit II and gong back(?) to Hookit. I just got up to II in the last year and will have lots of obsolete pads for DA's, an air file, hand sanding boards and blocks. Man, this sucks. As of DEC 31, 2010 it will no longer be produced by MMM. Looks like I better start stocking up.
Old 06-29-2010, 04:38 PM
I'm sure they will make some conversion pads. There are a lot of shops that have completely switched over to II.
Old 06-29-2010, 10:17 PM
roger1's Avatar
Only had a little experience with hook-it II. But, I didn't think it worked well at all. Glad to see it go.
Old 06-30-2010, 07:08 AM
deadbodyman's Avatar
Wiki Edits: 11
I wasted a crap load of cash buying those pads as soon as I had all the hook-it 1 pads they came out with the hook-it 2 at 30.00 a pop I hated buying them (they got me again) my butts still sore ...then they pulled the same crap with the panel weld glues I had to buy the special gun at 50.00 and they changed the tube sizes so you had to buy another 50.00 gun...
But 3-M paper just isnt that good anymore..and dont even get me started on those rolls of gold sticky paper (what a rip-off)...I was using the Imperial paper until I tried Fandelli made in Mexico its far superior in every way.and cheaper its hard to wear a piece out.the 36-80 grits are absolutely fantastic and the best I've ever used but so are the finer grits available all the way up to 1200 in 6" DA ....
As far as 3-m goes ....good bye and good riddance
go screw yourself for a change and give my butt a rest.
Old 06-30-2010, 07:52 AM
Thanks Michel, now I need to find a source for the Messican paper you use. Do they also have a hook and loop fastening system and not just sheets?
Old 06-30-2010, 08:16 AM
Wiki Edits: 11
yes ,but the paper has a soft felt on it .....I can get you in contact with my guy "Eddie" and he can hook you up with a local distributor if you like...PM me and I'll give you his number...
I use a german paint gun because I buy the best I can ,I dont care what country its made in as long as its the best bang for my buck...and if theres a country that needs money its Mexico mabee we can keep a few of them in their own country if they have a job working at a sandpaper factory....
Old 06-30-2010, 09:13 AM
Carborunum is also a great paper. http://www.levineautoparts.com/caforinma.html
Old 06-30-2010, 09:16 AM
I never thought of Carborundum for sandpaper, just wetstones and other stone related abrasives.
Old 06-30-2010, 09:48 AM
Wiki Edits: 11
The thing I really LOVE about fandelli 's coarser grits like 36-80 is they have a cloth type material backing that wont tear when you run into a sharp obstruction like paper will...a box seams to last forever..
some times you find a product that is so good you stop looking for something better or cheaper...like my Epoxy primer and clear ...this is one of those products.....head and shoulders above the rest...I've been useing it for a few years now ....
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 12:59 PM
Chevy II Front Clip Help LuvRod Suspension - Brakes - Steering 33 08-26-2009 04:08 AM
Chevy II front end vrs. Mustang II david6chevy Suspension - Brakes - Steering 2 08-19-2009 08:48 AM
Must II p.s. Don Meyer Suspension - Brakes - Steering 4 06-16-2004 12:28 PM
Are Mustang II Crossmembers Safe? Jon Suspension - Brakes - Steering 14 10-17-2003 01:43 PM
