Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mobil 1 10w30
Thread: Mobil 1 10w30
Old 09-20-2012, 03:42 PM
spinn spinn is offline
You have to be safe if in Toms case. When I build something and it ships out the door, it is going to be hammered right away. They almost never honor a breakin period for a engine or clutch.
Never flattened a cam. Intake leaks, after heat cycle bolts loosen, valve seals leak, header leaks claimed as internal problem, ring failures, bent rods, that kind of stuff.
