Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Modding fuel tank
  #21 (permalink)
Old 01-27-2013, 08:17 PM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by LATECH View Post
The pump isnt included, and can be changed. Its the fuel line fittings that is the main concern. The O ring style fittings pictured on this pump are correct for the 1987 El Camino with fuel injection
You will have to get the rest of the fuel lines from another source as the carb setup on the car as it is now wont work.
I'm not worried about the fuel lines at all. I've got the tools to change it over to AN.
It's getting the angle and length of the pickup and float arm that I'd be worried about. Not sure I want to invest in that sender, bend it up and not be able to get it right.
