The suggested " Hot Setup " back in the day was 37 to 41 ( round back ) spindles or 42 to 48 ( square back ) spindles. With 53 to 56 Ford F-100 brakes. I prefer the 42 to 48 spindles because the 53 to 56 F-100 backing plates have a square recess for the mounting area. You also have to grind some on the 37 - 41 spindles to get the 53 to 56 F-100 backing plates to fit. http://www.flatheadv8.org/f1brakes1.htm Click on the above link for a more details and part numbers DEUCE... |
I'm going for the old school,rat rod style and won't be running any fenders so I hope the drilled axle will work.The king pins in it are about 3/4". I'll have to find out the size of the king pins for the 37-48 spindles and go from there.Thanks Deuce for the help, Tom
I just recently fixed up the backing plates (48) to fit onto the Model A spindle which will accept the 41-48 drums. I machined a filler for the big hole in the backing plate, welded it in and the milled in the holes to bolt to the smaller diameter patern of the Model A spindle. This set up is going on a Model A pick up that will have the original 4 banger and driven at A Model speeds.
Trees |
| '40 Ford front axel on a T-bucket | Nightfire | Suspension - Brakes - Steering | 13 | 07-01-2005 10:46 PM |
| spindle question | dinger | Suspension - Brakes - Steering | 1 | 03-07-2004 05:45 AM |
| Model A pickup body swaps | alegath | Body - Exterior | 4 | 02-21-2004 01:03 AM |
| Hotrodders Knowledge Cluster: Front Clip Installs/Subframes/Frame Swaps | Jon | Suspension - Brakes - Steering | 0 | 10-12-2003 03:56 PM |
| confusing question about cars and their weight | stonedchihuahua | General Rodding Tech | 14 | 03-27-2003 03:00 PM |
