How would i fill the gap in between the top of the roff and the body, i used coulk, but it didnt work, would putty work, i hope u can help because i have a show to be at in 2 weeks.
I like to use JB Weld 5 minute epoxy or Bondo. dry very fast and don't shrink like model body putty does.
[ July 16, 2002: Message edited by: big dreams ]</p> |
Don't know just how old you are but if you're real careful you can melt a scrap of plastic into place with a soldering gun. Then sand and touch up with primer and sand again. I use this method on plastic auto parts all the time. The stress is on careful.
Model stores sell sheet styrene and you could do a chop just like the real thing. One of the neatest things you could do is get some 3/32 styrene rod and use a dremel tool to perform some plastic welding. Use model filler for the fill.
Outlawed tunes from outlawed pipes |
I'll make tip of all your ideas, i used the dremel tool to do the chop, and then sanded it to a smooth surface, i glued the front roof parts, then i put coulk on the back part(its a 49 ford sedan delivery), then i painted primer, glued the inside (for save keeping), the coulk broke off after it dried. I was very mad after all that hard work , i wish/hope the putty works!!!
| Model car update | matt167 | Off-Topic | 4 | 09-26-2006 04:07 PM |
| Car rolled over close to home... | schnitz | Off-Topic | 1 | 11-20-2005 01:10 PM |
| First paint scheme for '59 Caddy by me | Nightrider | Body - Exterior | 54 | 07-05-2005 02:27 PM |
| Picking a color | Wmarden | Body - Exterior | 6 | 10-23-2004 11:13 PM |
| Need color/top ideas.... | Cracker Red | Body - Exterior | 4 | 09-07-2004 08:14 PM |
