model a cowl question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2011, 10:55 PM
is there any major differences between a 28 model a sedan cowl and a 28 pick-up cowl? some one told me the windshield might be a little taller, but if that's true it wont matter in my case.
thank you,
Bryan
Old 01-04-2011, 09:12 AM
BOBCRMAN@aol.com's Avatar
Is the sedan cowl Ford, Murray or Briggs?
Old 01-04-2011, 04:09 PM
Its a truck cowl im thinking about buying to put on a sedan body I have that is missing the cowl. The cowl is to far away to just go and look at it and take measurements to see if there is any differences.
Old 01-04-2011, 05:07 PM
If the sedan is a Tudor, the cowl will be the same.
If it's a fordor, it's probably a Murray, or a Briggs body, and it will be different.
I don't think there was a Murray, or Briggs built tudor body.
Now I've thought about putting a briggs cowl on a '30 model coupe, 'cause that way I don't have to destroy a good gas tank, or buy an aftermarket top piece to replace the gas tank.
Old 01-04-2011, 05:16 PM
It a tudor body, so the truck cowl should work just fine for me then.
question on putting a 30 model a cowl on a 28 a sedan new_rat_rodder Body - Exterior 9 11-24-2010 11:25 AM
Model T Sedan top question jasonbeam Body - Exterior 2 09-16-2006 03:21 PM
model a cowl measurments spud Body - Exterior 2 08-08-2006 03:32 AM
Painting in cowl vent question. Skipr Body - Exterior 6 03-01-2006 06:37 PM
'85 model 305 timing question kf4ozb Engine 2 07-27-2004 02:58 AM
