model a dash/gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2006, 04:30 AM
I am replacing firewall on a model a. I am going to use the upper gas tank.I will use the front of the tank as my dash.I cut everything out and set the tank in.So far so good.The dash from the inside is about five inches back from the door post.I believe that after market dashes or 32's are flush with the door post. I will be putting a/c in this car.It doesn't look like there is enough room behind the dash.I will need that five inches for anything i put behind the dash.Any suggestions?
Old 01-30-2006, 07:47 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The dash that I built for my Model A is flush with the door posts, my gas tank is in the trunk so I have plenty of room behind my dash as I cut the original gas tank out because I did not want to drive around with a tank of gas in front of me.
Model A, Model T Gas Tank?? my51chevy Body - Exterior 4 11-13-2005 12:35 PM
FUEL TANK FOR 1928 Ford A MODEL PICKUP Malcolm W. General Rodding Tech 1 07-21-2005 10:57 PM
80' model Vette Fuel Tank, How do I fix a leak? 9.8sec. Hemi General Rodding Tech 8 05-16-2003 06:30 AM
model a fuel tank ridener Hotrodders' Lounge 4 10-29-2002 12:21 AM
1972mustang gas tank in a model a ridener Hotrodders' Lounge 2 05-21-2002 03:23 PM
