Model A doors Again - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2008, 03:19 PM
Last journal entry: interior wood work
Model A doors Again
Hey I know the responses in the past to flush fitting model A doors have been very limited so here we go again I installed auto loc hidden hinges in a 30 tudor and mounted the doors suicide now i want to flush the doors in I am leaning towards trimming the doors down the B pilar side and addind a angle channel across the top to inset the top of doors seems how I filled in all the drip rail and smoothed it. I think removing the overlap will allow the doors to open a bit further without hitting the qaurter panel has anyone else tackled this in the past and have other ideas or suggestions or pics woulds be great. thanks for the help
Old 09-24-2008, 04:17 PM
adtkart@aol.com
I'd have to go out and check the doors on my Tudor, but I imagine that the outer panel is folded over the shell, like most are. That means, if you cut the edge of that door, the outer panel and shell will separate.
Aaron
Old 09-24-2008, 04:18 PM
Arrowhead's Avatar
EFI Rules and Carbs Drool
Last wiki edit: The FREE T Bucket plans
Last journal entry: Sold Everything for a new project
Wiki Edits: 5
I can't help you much, but I'd like to see some pictures of your hinge setup.
I'm hoping to start my model A sedan soon too, I already have the body and would like to flush fit the doors as well. What I was thinking of doing extend the body an 1" at the door sill and header. Then the door can be left as is.
Mine has no roof and i'll be building a custom frame so it might be easier than changing the doors.
Old 09-25-2008, 08:44 AM
I will try to post some pics soon. The doors do just wrap the frame and pinch over it then are spot welded every so often my plan is to cut 3 to 4 inches off at a time and the tack the sheet metal and frame back together so it doesn't separate to bad we'll see anyway if that works. I did a little of the A pillar side to try and make my door gap perfect it will definitely take some serious time to do the whole door
Old 09-25-2008, 04:50 PM
adtkart@aol.com
Keep in mind while you are trying to make those gaps "perfect" that they overalpped them for a reason. The bodies flexed considerably, and unless they are really stiffened up, the gaps will change a bunch.
Aaron
Are all Model A chassis the same? HotRodKush General Rodding Tech 12 03-16-2010 08:05 AM
Repro 60-66 GM truck doors; anyone tried them yet? F&J Body - Exterior 0 11-13-2007 11:55 AM
10 ft wide garage doors.............. poncho62 Garage - Tools 3 08-27-2007 06:03 PM
1936 chev model numbers fixit General Rodding Tech 3 10-18-2003 02:28 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
