Model A Exhaust - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2011, 05:40 PM
Last journal entry: Here she is
Model A Exhaust
hey guys I am building a 1931 tudor sedan that is pro street and full fendered under stock width fenders. I am running an all stainless 2.5 inch exhaust system. The problem is I don't really have the room to go over the rear end and I don't want to run dumps. I see alot of people go under the rear end on these but I am not sure how close to go to the housing so that it doesn't get hit. I am running a art morrison ladder bar kit with coilovers. what is the potential down travel any ideas? thanks alot
Old 01-09-2011, 09:35 AM
LATECH's Avatar
Maybe you could post a few pics along with your question, so as to help paint a clearer picture of the build in question. Thanks
Old 01-09-2011, 11:43 AM
bondo's Avatar
Ayuh,... Measure the clearance with the car at rest,...
Then jack it up til the tries are off the ground, 'n Remeasure...
That's the clearance ya need...
Old 01-09-2011, 11:49 AM
bigdog7373's Avatar
Of course it's fast
How bout if the exhaust exits in front of the back tires?
Old 01-09-2011, 11:52 AM
Irelands child's Avatar
How 'bout a '31 with a '32 gas tank for closeness. That's a 9" hung with a TCI coilover 4 bar suspension. The pipes are 2-1/4
Lots of room!!!! That is as long as you don't try to go over the axle
Dave W
Irelands child
Old 01-09-2011, 10:00 PM
471A
I have run A sedans since 1980. The current configuration is a street-strip full fendered 29 Tudor with a Dana 60 rear, TH 350, and 4:71 blown SBC which runs 11.20's in the quarter and idles safely to the supermarket on errands. For exhaust, we welded in a "Y'" just rear of the header flange. When I drag race, I can bolt in an open exhaust flange that runs along, and then behind, the running boards on either side. The "street" exhaust runs, similarly to what already has been very helpfully depicted in the earlier photos, beneath the rear axle.
Early model roller cam in a later model motor? ricksgtx Engine 6 09-05-2010 05:04 PM
Exhaust f/28 Model A coupe fred56 Engine 5 08-10-2008 10:18 PM
early model vs. late model 350 blocks quincysmith Engine 11 08-15-2007 12:12 PM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 06:55 AM
exhaust for chev engine in model-a bettylew Engine 5 01-12-2003 07:59 PM
