Model A Front End - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2007, 10:56 AM
Model A Front End
I am relatively new at this so please bear with me. My brother-in-law and I have a project '29 Model A Fordor that I want to update with current technology. All I keep hearing is to replace the front end with a Mustang II front end, yet my brother-in-law says he has seen cars like this with the original suspensions and only the spindles changed out. Is this a) possible, b) Safe, or c) just stupid? Any help will make me feel a whole lot better!
Old 03-23-2007, 11:08 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Mustang two does not look good on fenderless model A's ( in my opinion) and if you run fenders there is really not enough room for the M-2. Yes you can either use your stock axle or you can do like I did...I used a four inch dropped axle ( aftermarket) to get the front end lower. You change out your front spindles using 37-41 ford type spindles. These are available as a aftermarket and you can get kits to put your choice of Ford or Chevy disc brakes on them. You can get everything you need from Speedway...they will even send you a free catalog. Go to www.speedwaymotors.com
Old 03-23-2007, 12:52 PM
Henry,
Thanks for the info! I ordered a catalog from the company. Lots of good stuff there. Do you have some pics of your car that I could see? Thanks again,
John
Old 03-23-2007, 01:06 PM
Henry,
John
Old 03-23-2007, 01:38 PM
Lost in the 60's
Wiki Edits: 4
Originally Posted by jfarneti123
Henry,
John
Thats my car in my Avatar.....there are more pictures of it in my photo album. Look up in the upper righthand corner of this post and click where it says Henry Highrise's photo album.
Lowering front end fred56 Suspension - Brakes - Steering 6 01-23-2007 09:30 PM
1930 Model A Front Suspension/Steering/Brakes jasonbeam Suspension - Brakes - Steering 2 02-02-2006 01:16 PM
69 nova has a front end shimmy over 50mph sfrymoyer Suspension - Brakes - Steering 3 09-27-2004 09:55 PM
Corvette tilt front end? shovelrocker Body - Exterior 4 01-13-2004 05:55 PM
Tables of rear end and front end dimensions willys36@aol.com Transmission - Rearend 1 08-21-2002 05:33 PM
