model a fuel tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2002, 07:06 PM
New Member
Post model a fuel tank
Iam put a fuel tank in my model a 2 door coupe behind the seat. the fuel line hook on top of the tank . just wondering if a manual fuel pump would work or would i have to go to a electrical fuel
pump. this this tank is from r c i racing any help would be nice thanks
Old 10-27-2002, 07:24 AM
adtkart@aol.com
Post
I don't know if you got a response to your question, so here goes. The type of fuel pump depends on the engine. If it is fuel injected, it will normally need an electric pump. That is due to the need to have the pressure heald constant. As far as the location on the fuel lines on the tank, it won't matter as far as what type of pump you use.
Old 10-27-2002, 08:48 AM
New Member
Post
I THINK HES RIGHT ABOUT THE INJECTED ENIGINE IT DOES NEED AN ELECTRIC PUMP BUT IF I HAD A CHOSE I WOULD GO 4 A MANULE PUMP 4 A FEW RESON THEY ARE LESS EXSPENSIVE AND IF U RUN UR CAR LOW ON FUEL AND MAKE A SHARPE BREAK WAT TENDS 2 HAPPEN IS AIR GETS IN 2 TEH TANK AND WILL STALL THE CAR AND R HARD 2 GET GOING BUT WILL A MANULE PUMP U GET SUM1 2 PUMP IT THROUNGH WHILE U TERN IT OVER IT SHOULD START BUT WITH AN ELECTRIS PUMP IT MUCH MORE HARDER 2 LOND 2 GO IN TO
Old 10-27-2002, 11:23 AM
Post
Pickup trucks had a similar arrangement for years concerning tank and line location. The manual pump worked well with a carburetor(s).
Old 10-29-2002, 01:21 AM
SuperFrog's Avatar
Speed is a question of money..
Talking
Ridener:
I've got a Model A coupe myself with the same setup (small tank behind the seat with a top/drawing line) and my manual pump (carbureated 305) has worked fine for years, but I'd suggest you get the tank out of the cab altogether and maybe look at the rear mounting '32 type types that fit in between the frame rails. It opens up alot of space in the cab of the car and usually allows you to put a little larger tank on.
Another reason I'd urge you to get your tank outta the cab is because mine ride was hit and my tank (an older Chevrolet tank)cracked enough to leak slightly into the floor of my coupe. Notwithstanding that pesky electical wire thing, the coupe smelled of gasoline like crazy till I pulled the tank (pinhole crack-enough to cause trouble). Ruined my carpet.
Keep 'em running, but keep 'em safe first.
SuperFrog
[ October 29, 2002: Message edited by: SuperFrog ]</p>
