Model A gas tank - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2008, 01:11 PM
Model A gas tank
I have a 28 Model A coupe that still has the original gas tank. I would like some room behind the dash for heater/air so the gas tank has to go. Can anyone give me the rundown on how to remove the gas tank/cowl so I can cut it open for room? Thanks - Jerry
Old 02-27-2008, 09:52 PM
First off, is the tank empty? It has to be completely empty, dry, and free of gas and fumes. Dont do any work on it until this is the case! Once u get to that point, remove (inside the car) the top dash rail and dash board and steering drop and you will now see the underside of the tank. What I did was cut the underside of the tank out using an angle grinder with a cutoff wheel. I didnt have to remove the tank from the car at all. be careful not to cut through the cowl, firewall, and exterior top of the tank. hope this helps.
Old 02-28-2008, 08:31 PM
Model A gas tank
Thanks for the info Leaky Pipes. I'll look at it tomorrow.
Thanks
welding on gas tank oldred Hotrodders' Lounge 15 01-21-2012 10:49 AM
Model A, Model T Gas Tank?? my51chevy Body - Exterior 4 11-13-2005 12:35 PM
Gas Tank Plumbing Follow-Up Doc68 Engine 0 01-11-2004 07:28 PM
gas tank relocation toddtheodd Engine 10 01-07-2004 11:45 PM
replacing gas tank in 29 Ford pikalpha Engine 2 12-10-2001 04:45 PM
