Model A headlight custom mount - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2011, 08:29 PM
Last journal entry: Here she is
all right here is my plan, I have 31 Tudor sedan that I'm running a 32 grille shell on. I don't want to run the normal headlight bar so I am thinking about cutting the mount cup off the original bar and using a hole saw in the side off the grille shell. then I want to flush the cups into the shell and weld them in. I think this well still give me the ability to aim the head lights. This would lower the light considerably and tuck them close to the fenders. So here is my concerns is the stock steel strong enough to hold the light with out major reinforcing and the stock bar sure adds strength to the fenders. I'm planing on filling the original holes and welding on some all thread and bolting the fender to the mount from underneath. has anyone seen a mount the would work better or has anyone done this before. keep in mind my car is full fendered and hi boy mounts won't work[IMG]PB250430[/IMG]
Old 03-29-2011, 12:13 AM
327NUT's Avatar
I read your post and I must confess...I am a very traditonal guy when it comes to the 29-32 Fords. I have seen other examples of owners trying to have a different look with their headlight locations but in my opinion they just don't look right....my opinion only mind you and as I always say....to each his own.
I don't think that w/o a lot of re-inforcing the inside of the rad. shell that the headlights wouldn't "dance" around a little. As you mentioned, the headlight bar was there for a reason. If you're running a '32 shell then I would run the dropped headlight bar and '32 or '34 commercial headlights.....but thats just me.
a simple headlight mount clean up mod pepi Body - Exterior 0 12-30-2008 06:53 AM
Model A headlight wiring cbass139 Electrical 4 09-19-2008 10:26 PM
Anyone into Custom model cars! PRO 48 fleetline Hot Rod Art 2 01-10-2008 04:08 PM
Custom motor mount bracket help mkloter Engine 1 12-06-2007 12:36 AM
"49" Ford Business Coupe Custom Transmission Swap standard to late model Automatic Rockin Rick Transmission - Rearend 4 10-14-2003 01:40 PM
