Model A rear buggy spring - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2005, 11:03 PM
What is the best spring to run on the rear of a model a? I am building a car and using the stock spring set up and i want to lower it as much as i can.
Old 06-10-2005, 03:58 AM
adtkart@aol.com
If you have the original spring, you can remove some of the leaves to get the stance you want. Remove every other one.
Old 06-10-2005, 07:35 AM
As one of the Moderators here....let me be the first to WELCOME YOU here..
Most folks who retain a transverse spring under a Model A , use a aftermarket ( new ) spring made just for the purpose. It has reversed eyes ( 1 inch lower ) and the curve is less so that the Model A will sit lower while still having a soft spring rate for a good ride. The old Model A spring was engineered to hold the Model A up high ( 19 or 21 inch tires originally ) and the ride was not much of a concern back then.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Rear ends... chrisflock Transmission - Rearend 12 06-04-2005 09:05 PM
1930 Model A Rear End Swap jnex Transmission - Rearend 4 04-16-2005 03:28 AM
8 1/4 to 8 3/4 rear end Leaf Spring Problem... 71gtx Transmission - Rearend 21 04-19-2004 07:17 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
