-   -   model a spindles (http://www.hotrodders.com/forum/model-spindles-224532.html)
big block camaro 09-30-2012 02:22 PM
model a spindles
hi does anyone know if they make a disk brake conversion that fits stock model a spindles? most i have seen only fit 37 and up ford spindles. do u have to upgrade to 37 and up spidles? or does anyone know how to identify model a spindles or 37 and up spindles? any info would be great thank you.
BOBCRMAN@aol.com 09-30-2012 03:56 PM
Model A spindles have detachable arms that bolt thru the unit. 37 on, the arm is part of the spindle forging.
big block camaro 09-30-2012 05:11 PM
thank you that helps alot!
timothale 09-30-2012 05:30 PM
speedway parts
I have read that you can use the adaptor sleeves for putting 40's drum brakes on a model A to use the common swapped disc rotors on the A spindles, Ford F1, 48 to about 53, spindles are also supposed to be able to be used on an A axle, I have a stock A axle spare for my roadster, F1 spindles, and 40's spindles with 65 mustang K H 4 piston discs, 46 lincoln front end in the parts rack. The A presently has 40's drum brakes., axle.
