model a spindles - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2012, 02:22 PM
model a spindles
hi does anyone know if they make a disk brake conversion that fits stock model a spindles? most i have seen only fit 37 and up ford spindles. do u have to upgrade to 37 and up spidles? or does anyone know how to identify model a spindles or 37 and up spindles? any info would be great thank you.
Old 09-30-2012, 03:56 PM
BOBCRMAN@aol.com's Avatar
Model A spindles have detachable arms that bolt thru the unit. 37 on, the arm is part of the spindle forging.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
big block camaro (09-30-2012)
Old 09-30-2012, 05:11 PM
thank you that helps alot!
Old 09-30-2012, 05:30 PM
Wiki Edits: 27
speedway parts
I have read that you can use the adaptor sleeves for putting 40's drum brakes on a model A to use the common swapped disc rotors on the A spindles, Ford F1, 48 to about 53, spindles are also supposed to be able to be used on an A axle, I have a stock A axle spare for my roadster, F1 spindles, and 40's spindles with 65 mustang K H 4 piston discs, 46 lincoln front end in the parts rack. The A presently has 40's drum brakes., axle.
The Following User Says Thank You to timothale For This Useful Post:
Early model roller cam in a later model motor? ricksgtx Engine 6 09-05-2010 04:04 PM
early model vs. late model 350 blocks quincysmith Engine 11 08-15-2007 11:12 AM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
model a spindles lowbuck Suspension - Brakes - Steering 2 08-18-2003 05:29 PM
What car (make and model) can be use to place a Model A body? Fortingo General Rodding Tech 7 05-10-2003 03:25 PM
