model a steering trouble
Ok so I have a 1931 model a woody it has a vega steering box and a flaming river steering column what shafts and u joints do I use any help will help thank you
Speedway time
Speedway motors has a couple pages of steering components in the catalog. , It depends on what the end of the column has ? 3/4 round or 3/4 double D, double D is the most common, and check the vegs size and spline count . Mine was 5/8 36 spline , then select the U joint or coupler with the size you need Speedway sells new shaft material. Measure 3 times cut once. fit everything together, the allen screws will make a mark. take it apart and drill a small drill point recess for better locking of the allen . after it was together and a test drive I tig welded some of the connections that only used an allen screw. lock tight or nylock nuts on the thru bolt connections.
| late model monte carlo trouble, wont idle right?? | tiresmoke55 | Engine | 3 | 05-04-2006 10:29 AM |
| Late model GM Steering Column for Model A | Woody31coupe | Suspension - Brakes - Steering | 3 | 12-31-2005 05:55 AM |
| power steering trouble | paladin | Suspension - Brakes - Steering | 2 | 07-21-2005 09:11 AM |
| Steering wheel trouble | J. Cooper | Interior | 3 | 07-05-2003 03:46 PM |
| steering colunm trouble | jeff germano | Suspension - Brakes - Steering | 4 | 12-10-2002 08:56 AM |
