model a suspension
Ok here's one I haven't seen yet. Is it possible to build a 4 link rear suspension for my model a w/350/350 combo and a 9" using the original "wishbones" as the lower links, modified to a single bolt mount on the rear and an adjustable front bushing. The uppers would be standard 4 link pieces. And I'm using the original high arch rear spring mounted behind the rearend instead of on top. will the wishbones be strong enough for lower links? I want the traditional split bone look but don't think they are strong enough as a ladder bar setup. thanks for any help or advice.
Original Model A wishbones are not a good idea. You might get away with that using 35-48 rear or front wishbone whichever suits your length requirements, as the later ones are welded tubing and more substantial than the As.
Not sure if you would want to use a four bar set up with the spring your talking about. There are several books that explain why a four bar would be used and this is not one of them. Either the later split wishbone or a set of three point radius bars would be my suggestion.
Randall |
| '29 Ford Model A Suspension | jfarneti123 | Suspension - Brakes - Steering | 4 | 11-29-2005 11:14 AM |
| Model A front suspension | Alecigio | Suspension - Brakes - Steering | 11 | 08-24-2004 07:58 PM |
| suspension for a model | hot_rod_kid | Suspension - Brakes - Steering | 1 | 07-18-2002 02:03 PM |
| Model A Suspension | autorat_02 | Suspension - Brakes - Steering | 3 | 06-19-2002 06:37 PM |
| mustang/pinto suspension on a model A | 30coupe | Suspension - Brakes - Steering | 6 | 04-10-2002 07:47 PM |
