model a suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2011, 10:35 PM
model a suspension
Can anyone give me an estimate on front suspension distance travel on a 32 ford frame? I have a new tci 4" drop axle with multiple leafs. I need to know approximately so I can set the rear end where I want it which is level. I have the frame leveled in a jig. I want only the tire diameter to give a slight rack, not the suspension. Thank you
Old 11-15-2011, 06:48 AM
jalopy45's Avatar
Just a little confused here, if you wanted it level, why install a dropped axle? If you want the chassis level wouldn't you want to reduce rear height by 4"?? Maybe I'm over sinplifying it?
Old 11-15-2011, 08:39 PM
model a suspension
No, I am building the chassis at level. Ride height would be a different issue. (your drop axle question) I want the front and rear wheel center line built level as well so that the rack of the vehicle will come only from the tire diameter different size. So I am trying to determine how much travel the front suspension will have (with the weight of a small block), so that I can set up the rear axle accordingly. Thanks
model a suspension msherrow Suspension - Brakes - Steering 2 01-25-2007 08:51 AM
Model A Front Suspension loiselle Suspension - Brakes - Steering 3 02-17-2004 04:49 PM
Model A Suspension loiselle Suspension - Brakes - Steering 0 08-26-2002 03:06 PM
suspension for a model hot_rod_kid Suspension - Brakes - Steering 1 07-18-2002 02:03 PM
Model A Suspension autorat_02 Suspension - Brakes - Steering 3 06-19-2002 06:37 PM
