Model T aluminum spoked wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2011, 05:44 AM
Has anyone ever tried to turn a set of replacement spokes for a model T ford out of aluminum? I thought I might give it a try with some 6061 stock. I made new wood ones in the past, why not metal? any thoughts on this working using a metal lathe and bridgeport...
Thanks
Old 11-04-2011, 05:50 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Sounds like a plan to me...Go for it..Might upset a purist or three though..
Sam
Old 11-04-2011, 07:01 AM
Wiki Edits: 27
spoked wheels
The geometry of spoked wheels. It started with horse drawn carriages. When the rim of a wood spoked wheel gets a side push it loosens the spokes. Carriage wheels were dished, and the wheel was cambered so the load pushed the rim towards the center line thru the hub. That's why bike and motor cycle wheels have the hub offsets with spokes started on opposite sides, and the spokes are under tension. Wood spokes are only under compression loads. . Aluminum spokes, rims and a lot of TIG welding needed. I have seen some neat looking wheels, cast centers from trucks of the 20's. A neighbor did a lot of Demolition work. and had a bunch from Farms that were getting developed into housing. The last time I checked he only sold one set and the rest went to the scrap yard.
Old 11-05-2011, 11:22 AM
Are you telling me that someone has done this and they work? Does this person still have any sets made? 21" in the front and 20"s in the rear is what I have.
Thanks
Old 11-05-2011, 04:37 PM
Wiki Edits: 27
old wheels
they were original steel wheels from the 20's. all but one set were scrapped.
Old 12-04-2011, 05:01 PM
[QUOTE=TT Dog]Has anyone ever tried to turn a set of replacement spokes for a model T ford out of aluminum? I thought I might give it a try with some 6061 stock. I made new wood ones in the past, why not metal? any thoughts on this working using a metal lathe and bridgeport...
Thanks
new tires for T bucket spoked wheels sparkyct55 Hotrodding Basics 1 04-09-2008 11:00 PM
Aluminum wheels Guy Hiltz Hotrodding Basics 4 09-30-2005 10:12 PM
Aluminum wheels Lowgmc83 Body - Exterior 5 12-23-2003 05:15 AM
aluminum wheels ? jum Body - Exterior 7 12-10-2003 10:45 PM
Old aluminum A/R wheels... Steve Lawn Body - Exterior 4 05-02-2003 09:18 AM
