Model T brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2011, 11:58 AM
Model T brakes
I have a TT Ford truck. I sold the driveline and are planning to make it look like a stock farm truck but with a late model v6 engine/trans and rear. My question is does anyone make or know how to fit disc brakes on a stock T front end? Can I change spindles that will adapt the original wood spoke wheels. I can change the wishbone to a 4 link. I can keep or change the steering. But how may I keep those old wood spoke wheels? It does not have to go fast, I just want more than the original 20 hp engine.
Thanks
Old 10-29-2011, 12:45 PM
327NUT's Avatar
There are several company's that make disc brake conversions, www.speedwaymotors.com may have a setup. Not that you don't know this but just keep in mind that those OLD wooden spoke wheels were not made for any kind of horse power whether you use disc brakes or not. You also might google a Model T club and ask them your question, maybe one of those guy's has done the conversion........good luck.
Old 10-29-2011, 08:46 PM
Wiki Edits: 27
T disc's
Someone is making disc brakes for a T pass car suspenion. Why not go to a later Ford V8 axle and run wire wheels ? The wood spokes on my Model T speedster used to make noises when I hit bumps or turned. I wondered when I was going to be scraping on the ground with a pile of kindling. I changed to 27 wires , Some guys run early chevy (20's) disc wheels. 6 bolts that match the T 6 bolt wood hubs. It's supposed to be an easy swap. Check out MTFCA or northwest vintage speedster.
Old 10-30-2011, 07:39 AM
delawarebill's Avatar
T bk upgrades
i did a google thingie and found "wilwood.com" to have an article of just what u want. see if it helps
Old 10-30-2011, 08:27 AM
Frisco's Avatar
Glad To Be Here
I found several links concerning the installation of disc brakes on the Ford Model 'T'. They all appear to be for the rear axle only and for the same manufacturers kit just different distributors.
I can not find any reference to install disc brakes on the original front spindles of the Ford Model 'T'. The Model 'T' Ford with the wood spoke wheels did not have front brakes originally.
If you swap the front axle to a later year (Model 'A' and up to 1948 Ford), then there are several kits available to install disc brakes on the later 1937-1948 spindles.
Here is Link 1
Here is Link 2
Here is Link 3
Here is Link 4
Because of the slow operating MPH range of a stock Model 'T' Ford, the wood spoke wheels may be acceptable to run. Personally, I would consider upgrading to later Model 'T' wire spoke wheels or Model 'A' Ford wire spoke wheels.
Old 10-30-2011, 10:49 AM
Thanks for the info
Thanks for the information. I'l look into everything. Just wondering. Ever see anybody turn a set of aluminum spokes to look like the original wood ones? I have a lathe.
Old 10-30-2011, 11:04 AM
I would be really concerned about the torque applied to straight wood spokes, by a brake trying to stop the hub, and the tire wanting to continue rolling
Old 10-30-2011, 03:27 PM
Irelands child's Avatar
Model T's did not have front brakes - at least the passenger cars. This outfit seems to offer some sort of discs, but after just a quick look. you would need to change wheels at a minimum - and no clue as to what else.
Irelands child
Old 10-30-2011, 06:28 PM
Thanks, I looked at the site. Not sure about the T. Search dates went back to 1936 cars. Also seemed expensive for what started as a low buck project for me. I appreciate your input.
George
Old 10-31-2011, 08:15 AM
Frisco's Avatar
Glad To Be Here
This link is a good one and should be interesting info for the OP. It does show pics of disc brakes with the wood wheels on the front axle using the stock Model 'T' Ford axle and spindles. It also posts very important info concerning the front radius rods when using front brakes on the stock 'T' axle and spindles.
Old 11-01-2011, 10:51 AM
What link showed the disc brakes with wooden wheels on a stock T front end?
Also, i'm new to this site and just registered. Hope I replied correctly. Don't want to insult anybody by not responding. Thanks to all who offered information.
Old 11-02-2011, 08:10 AM
Wiki Edits: 27
T disc brakes
Go to the HAMB site and search Model t speedster. The site search does not work very well to find what your are looking for. I've seen a couple different Disc brake conversions posted there Powerwagonmaniac is building a speedster and there are picts of his conversion using Nissan 4 X 4 rotors. They use the Chevy 6 bolt pattern which is the same as model T wood bolt hubs.
Old 11-02-2011, 08:27 AM
Frisco's Avatar
Glad To Be Here
This link was originally posted by Ireland's Child.
Click on Model T front disc brakes to go there.
There are pics in the upper left. Scroll down for additional info and question and answers.
Old 11-03-2011, 07:38 AM
Wiki Edits: 27
late drive train
Back to the original proposal to use late drive train, V 6 etc. The T spindles . steering parts, are not up to the job . I would not use them on anything other than a T powered build.. Originally designed for a 20 HP vehicle.. A V6 would be way over any safety factor. The T spindle design does not have a lot of swap possibilities to anything strong enough. If you want the TT beam you could look at having a later model axle ends put on but That is $ more than it's worth. Some of the T dropped axles are welded. . made from 2 T axles. I have a couple of 20's Dodge front axles that are heavier, but are 2 spring. then using something that old..too much work to add discs,
Old 11-11-2011, 05:14 AM
Wow, lots of good info. I'm not sure which way to go now. I really wanted the original look with a simple late model engine for obvious reasons. I have collected original TT parts for over 15 years. My frame is like new and the body is close. It's just a hobby that I held onto like unlike all the great rides i sold and regreted later. Thanks for your insight. Someelse told me about the chevy 6 lugs.
George
Power brakes in Model A fred56 Suspension - Brakes - Steering 7 07-10-2011 05:40 PM
Best MC to use in Model A with Juice Brakes and original 4 cylinder aldixie Suspension - Brakes - Steering 4 06-18-2009 07:03 AM
How to set up Model A brakes orbeas Suspension - Brakes - Steering 1 05-23-2009 05:05 AM
Disc brakes model a Ibeam front speedydeedy Suspension - Brakes - Steering 2 11-13-2007 05:56 PM
Model A disc brakes WilderRods Suspension - Brakes - Steering 1 04-28-2005 10:24 PM
