Model A Wheels need help
Hey guys I am building a 1930 Model A Tudor sedan I put a 46" front I beam axle in it with a four inch Drop My car is full fender ed And I am running a narrowed 9" ford rear in the Back I am going to run the Mickey Thomson SR tires 29x18x15 I want to run the same style tire up front but not pizza cutters what rim size are some of you running with this same set up in the front and what Backspacing any help is much appreciated thanks Justin
15s 4 inch too 6 inch with ...depending on the room, stance, and steering. Back space depends on axle with, brake style and distance needed to clear the inside of fenders, at ride hight.
As to cookie cutter there are just so many options and that is the way it is , now how one puts the cookie cutter parts together, the proportions of the complete build will make it stand out in the crowd. |
I have a 46' wide axle with 37-41 spindles and disc brakes I want to run a 6 inch wheel but am having trouble figuring a good back spacing
I am going to run the Mickey thompson sr 26x8.00x15 tires it has a vega steering set up any one have any input? the wheels I want to run are the American Racing Hopster 15x14 out back and 15x6 up front the available back spacing on the fronts are 3.00 to 3.75 so I only have 4 choices either 3.00 3.25 3.5 3.75 any one remember the backspacing on a similar project?
| Turbine wheels? | burninrubbah617 | General Rodding Tech | 4 | 02-28-2006 02:15 PM |
| See different custom wheels on YOUR car! | HUH? | General Rodding Tech | 3 | 12-12-2005 11:46 AM |
| '73 Camaro wheels | lluciano77 | Transmission - Rearend | 1 | 05-05-2005 07:59 AM |
| What car (make and model) can be use to place a Model A body? | Fortingo | General Rodding Tech | 7 | 05-10-2003 03:25 PM |
| confusing question about cars and their weight | stonedchihuahua | General Rodding Tech | 14 | 03-27-2003 03:00 PM |
