Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
Old 11-27-2012, 08:20 PM
Irelands child's Avatar
Irelands child Irelands child is offline
I have a reinforcing framework around the entire pass. compartment in my '31. Lots of 3/4 and 1" tubing, both round and square. There is not a bit of the dreaded Model A cowl shake or body flopping
You do run into a problem with a steering column - too low, no room for 3 pedals. Raise it higher, then exhaust manifolds get in the way and you can end up with more then three U-joints and an additional support bearing.
Dave W
Irelands child
