Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
  #55 (permalink)
Old 12-18-2012, 05:55 PM
31ROC's Avatar
31ROC 31ROC is offline
Originally Posted by 1971BB427 View Post
You don't own a torch? I bet with a rose bud tip those could be bent over to miss everything, and work fine. I'd check clearances to determine if they need to be bent down low, or up higher. Either way will work, and one or the other will make it fit.
Might even have to do an offset bend to get the top to clear the column, and the bottom to clear any obstruction.
I dont think bending them as needed is the issue, i can bend any which way but loose, the real issue is overall length...to far forward so I can access the reservoirs, and its too narrow for the pedals, too far back for the pedal room, and I cant access the reservoirs.....talking to Pete & Jakes, they say cutting the pedals dwon shorter and I loose the correct "ratio" and will take two men and a horse to push the brakes!
