Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
  #56 (permalink)
Old 12-18-2012, 08:21 PM
lakeroadster's Avatar
lakeroadster lakeroadster is offline
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Keep the faith, you can do this! Looks like you'll have to bend the arms, move the assembly back a bit and modify the floor to get access to the master cylinders. You could also build spool piece that bolts between the bracket and the master cylinders to move the master cylinder to the rear more if you need to clear a crossmember.
What brake pedal assembly were you using before?
Here are your photos rotated.. seems easier to see.
