Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
  #62 (permalink)
Old 12-19-2012, 09:06 AM
alittle1 alittle1 is offline
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
I think, I would be going with a heat diffuser on that exhaust pipe as it ran by the booster and M/C. Using a perforated type would give you some good air flow where you need it. Also, consider the after-drive heat that will rise off of those pipes and heat soak into metal around them.
