Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
  #63 (permalink)
Old 12-19-2012, 10:17 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Originally Posted by alittle1 View Post
I think, I would be going with a heat diffuser on that exhaust pipe as it ran by the booster and M/C. Using a perforated type would give you some good air flow where you need it. Also, consider the after-drive heat that will rise off of those pipes and heat soak into metal around them.
It was considered but after several thousand miles - no problems though I have heat shields on the mufflers. I felt that heat would be better dissipated without any restrictions. A hand feel of the booster and MC show them to be just above ambient after a hard drive. Low mass of tail pipe thickness tubing, no cats, just wont retain heat more then a very few minutes
