Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Model A- where to mount the pedals?
  #65 (permalink)
Old 01-21-2013, 08:46 AM
31ROC's Avatar
31ROC 31ROC is offline
Well....after a short hiatis (sp?), back to getting these under floor pedals mounted. Have bent the clutch pedal arm as well as the gas pedal arm to a point where they are now mountable!
Had to add 7/8" to the length of the clutch pedal to match up with the gas once again. I have tacked the mounting bracket onto the frame, and once I make a new floor "patch", I will have a "pro" come in and tig everything at once.
Almost made the mistake of leveling the bracket as is.....but caught myself JUST IN TIME, since the front of the car is up in the air on ramps! Had to figure the incline out, and adjust bracket accordingly so when car is flat on ground the reservoirs will be level....PHEW!!!!
