I'm aware that 31ROC has a coupe - but I'm also well aware that once he pulls that gas tank and either cuts it off the cowl or just replaces it with an aftermarket version, much inherent strength is lost PLUS he also needs something to either mount pedals, e-brake handle, column drop, a/c or whatever else he wants in that under dash not-as-big-as-thought hole.
Gas tank already gone....this car was near finished when I bought, now its time to make it mine.....
I will attempt taking some pics tonite and post them, so you pros out there will get my issues.....I REALLY appreciate everyone's input being a hotrod newbie....
I have seen an under the dash booster, pedal assembly complete with master cylinder. It mounts sideways and has a crazy mechanism that operated the push rod. I was going to use that myself on my 30 model a, then I decided to just buy a booster/master cylinder that is chrome and mount it on the firewall. Got to say it looks pretty cool next to the chrome engine. The pedal system i used is out of a late model mustang cobra. The pedal are real sporty looking, and the are real nice and tight so they fit rather nice. You can usually find them for about $150-$200. Cant beat it.
You might look at the setups that put pedal assembly and masters all under the dash. It takes a hose to fill the units with fluid, but they're compact. Might again take some heat to bend the pedals to fit your car.
Wilwood makes them, and Speedway has them in their catalog.
And then there is Kugel Komponents - Reverse 90° Under Dash : Kugel Komponents, Quality Komponents Since 1969
As far as room, you have it with these Kugal parts. BUT - why the desire for a 4-5-6 speed manual? An auto will shift faster, be more reliable and the exterior parts are more easily located, i.e. under the floorboards. Yeah, I looked at running a 5 speed in mine, but after spending a bunch of time going through what you are now, said screw it!! A well built C4 will do everything necessary (TH-350 with a Chebbie). Very happy I did as trying to move size my size 12's attached to my 6'4" body to three pedals would have been not a good time for me at every stop. Yeah, a coupe has a little more room then a roadster, but not a heluva lot more. Today, and knowing what I know now and since I built from scratch tho using a TCI Stage lll chassis, would have extended the frame beyond the firewall a few inches then used a standard firewall as the 5" recessed version wouldn't be hurting my foot room. Whatever - it IS your car and choice, albeit a difficult project
Gotta agree with 31 ROC, having 3 pedals and rowing through the gears is a big part of the fun.
A lot of great information here. I still think the under the floor set-up is still your best option. A lot less fabrication and easier access. Cut out the drivers side floor pan, install the pedals assembly, then install a new floor pan that fits around the pedals and that has access doors for the master cylinders. All this can be done in a fairly accessible area and it will be hidden once your done. Here is a shot of my floor pan area for comparison. Old photo, that has been scanned, but thought it might be usefull:
if I can find a way to fit the dual pedal assembly under floor, I am thinking the pedals will have to pop up thru the floor "in front of the steering column" as opposed to on either side of it since there really is no room left of the column....is this reasonable?
| Model A headlight custom mount | Fastsx321 | Body - Exterior | 1 | 03-29-2011 12:13 AM |
| which pedals | project34 | Hotrodding Basics | 1 | 04-18-2008 02:17 PM |
| pedals | Hot Rod Mike | General Rodding Tech | 4 | 03-24-2008 08:06 PM |
| pedals pulsates | Augusto | Transmission - Rearend | 4 | 05-16-2007 08:06 AM |
| pedals | solowookie | Suspension - Brakes - Steering | 4 | 04-10-2002 06:13 PM |
