Model A- where to mount the pedals? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 11-29-2012, 02:04 PM
31ROC's Avatar
Originally Posted by 31ROC View Post
if I can find a way to fit the dual pedal assembly under floor, I am thinking the pedals will have to pop up thru the floor "in front of the steering column" as opposed to on either side of it since there really is no room left of the column....is this reasonable?
Anyone think this may work? Maybe the pedals will be to close?
  #32 (permalink)
Old 11-29-2012, 03:20 PM
31ROC's Avatar
Been searching for Munice M20 dimensions with no luck, any suggestions?
need height, length, width along with bell housing dimensions...
thanks
  #33 (permalink)
Old 11-29-2012, 03:43 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
That's the way thebrake pedal is on my Model A, look at the picture in post 29. The pedal are between the column and the driver.
Like I said previously, if you cut out the floor pan you can position the pedals wherever they need to go, then fill in the floor pan after you are happy with the ergonomics of the pedals.
As for dimensions, if you don't find anything I can put my '65 C10 up on the lift and post some photos / dimensions this weekend.
  #34 (permalink)
Old 11-30-2012, 05:40 AM
Sorry i tried to link up the pics of my set up but I can not find the cord that plugs into my computer. Send me your cell phone number and I can forward them out of my phone. I have to say to everyone out there that is so pro automatic transmissions. If I have to explain to you why a hot rod needs a clutch then I guess you just wont get it. If you want a daily cruiser go buy a lincoln town car. In my set up I was able to shrink my tunnel and have room for the column and all three pedals. I used 2" angle and fabricated a support system for the pedal assembly that is welded to the firewall and the top of the cowl support bar on the outer edge of the inside of the cowl. I did a complete pull up on it and it could easily hold me and you up. I then attached a piece of angle to the front side and mounted my column drop. The hole thing was quite simple and you can not even see any of the pedal assembly or the mount bars. My car does not have a/c but there is plenty of space to incorporate one. I put a/c in my 38 chevy and it was a pain in the ***. I think I have used it twice.
  #35 (permalink)
Old 11-30-2012, 05:47 AM
31ROC's Avatar
I wonder if I just get a couple of these, and be done with it?
  #36 (permalink)
Old 11-30-2012, 06:45 AM
They would work but I think they are costly and it will be much easier to mount an entire unit. I have driven cars with through the floor pedals and I simply do not like the feel of the clutch going through the floor. It's not natural. Believe me you wont have any problem mounting a unit up inside the cowl.
  #37 (permalink)
Old 11-30-2012, 08:57 AM
31ROC's Avatar
LMAO!!! you must think I know what I am doing!
Under my dash is a big empty cavern!
  #38 (permalink)
Old 11-30-2012, 09:53 AM
Last journal entry: It Will Work
I'm watching this thread to see what you come up with. I hate automatics. I plan on putting a Muncie in my 31 Plymouth. When I got it someone already had some pedals sitting in the pile of parts. I think they might have come from a Japanese car or truck. I have 2 sets of 3rd Gen F body brake and clutch pedals with the brackets. I have not tried to put them in yet. If I can get the F body pedals to work then I can use a GM steering column and a manual brake master cylinder.
  #39 (permalink)
Old 11-30-2012, 10:13 AM
31ROC's Avatar
Right now, I'm waiting fir a few helpful people to get me dimensions on a bell housing and Muncie M20..... Once I know they will fit, I think I'm going to try the individual floor mounted pedal assemblies. The vendor says I can return within 30 days.....I assume I will just need to run both hydraulic lines from back of floor mounted reservoirs thru firewall or the floor......I am still open to all and any suggestions!
  #40 (permalink)
Old 11-30-2012, 10:21 AM
I don't have bellhousing handy but I have the Muncie. They make a few different bellhousings so the dimensions will be different. The most compact bellhousing will be the one made for the small flywheel.
  #41 (permalink)
Old 11-30-2012, 03:09 PM
31ROC's Avatar
Do you have the height, length, and width of your Muncie? is it M20?
Thanks
  #42 (permalink)
Old 11-30-2012, 03:22 PM
A M20, M21 and M22 will all have the same dimensions. The length is 29 inches, the height is 9 inches and the width at the ears is 9.5 inches and the case is around 8.5 inches at the side cover.
  #43 (permalink)
Old 11-30-2012, 03:38 PM
A GM T10 and a Saginaw should also fit in the same space as a Muncie. The dimensions should be similar.
  #44 (permalink)
Old 11-30-2012, 04:09 PM
31ROC's Avatar
Thanks V-8!!
  #45 (permalink)
Old 12-01-2012, 08:34 AM
31ROC's Avatar
well...after constructing a mickey mouse cardboard "mock-up" of the dual m/c floor mounted brake pedal assembly, with VERY close dimensions, note in the picture THIS AINT GONNA HAPPEN.....not only will it not fit towards the right side of the steering column its not far back enough so that my knees are not under my chin,....back to square one......
Model A headlight custom mount Fastsx321 Body - Exterior 1 03-29-2011 12:13 AM
which pedals project34 Hotrodding Basics 1 04-18-2008 02:17 PM
pedals Hot Rod Mike General Rodding Tech 4 03-24-2008 08:06 PM
pedals pulsates Augusto Transmission - Rearend 4 05-16-2007 08:06 AM
pedals solowookie Suspension - Brakes - Steering 4 04-10-2002 06:13 PM
