I'm not even going to attempt to mount the pedals on the floor on mine. My frame has a X member right under the floor boards. If I can get the F body pedals to work then I have the option of using a hydraulic clutch.
My plan is to do it just like GM did it for years. The pedals are on a hanger with bolts going through the firewall to hold on the master cylinder and clutch master cylinder. The steering column bolts to the bottom of the hanger so there is no way the pedals interfear with the steering column. I have not tried it yet, I don't know if the the steering column angle will be right. I still need to do all the suspension.
I have some pictures of cars that have the brake booster and master cylinder mounted on the firewall. I guess it all depends on the style of car someone is building. The billet types want everything hidden. Some of the old style hot rods have the engine mounted up high so there is no room. I don't have a engine in mine yet, just the body sitting on the frame. I want mine to look old school and function.
![]() Length, including bellhousing ![]() Length, just the transmission
Well...bought the pete & jakes #2040 kit clutch&brake pedal assembly with master cylinders, and after many hours, cutting floor, and testing this assembly, I dont see anyway this is going to fit. Any one out there install this into a 31 coupe? I attached some pics to show my delimma!
You don't own a torch? I bet with a rose bud tip those could be bent over to miss everything, and work fine. I'd check clearances to determine if they need to be bent down low, or up higher. Either way will work, and one or the other will make it fit.
Might even have to do an offset bend to get the top to clear the column, and the bottom to clear any obstruction. |
Keep the faith, you can do this! Looks like you'll have to bend the arms, move the assembly back a bit and modify the floor to get access to the master cylinders. You could also build spool piece that bolts between the bracket and the master cylinders to move the master cylinder to the rear more if you need to clear a crossmember.
What brake pedal assembly were you using before? Here are your photos rotated.. seems easier to see. ![]() ![]() ![]() ![]()
So why not open the floor some more to access the reservoirs? Even if it's under the seat it can be filled with a basting syringe. I know guys who fill their reservoir with no visual access and just fill a little, and then feel to see how close it is.
I really think you're going to get this if you open up your options and get creative. |
I totally agree with 1971BB427. You can do this.
Envision your clutch pedal bent exactly the opposite of my brake pedal, as shown below. That would clear the column, and the bend would effectively shorten the pedal a bit also. [/
OK guys....I wont quit yet...thanks for the support!
Guess I need to get more creative... my previous brake pedal set up was the single pete&jakes kit with manual master.....I WAS considering exactly what you mentioned----bend the clutch arm exactly opposite of the brake arm (towards the left), just dont know what part of the arm is above the floor, and how much of it goes under the floor? The brake arm maybe I could bend it straight? |
A striaght edge across the floor should tell you what part will be under the floor.
| Model A headlight custom mount | Fastsx321 | Body - Exterior | 1 | 03-29-2011 12:13 AM |
| which pedals | project34 | Hotrodding Basics | 1 | 04-18-2008 02:17 PM |
| pedals | Hot Rod Mike | General Rodding Tech | 4 | 03-24-2008 08:06 PM |
| pedals pulsates | Augusto | Transmission - Rearend | 4 | 05-16-2007 08:06 AM |
| pedals | solowookie | Suspension - Brakes - Steering | 4 | 04-10-2002 06:13 PM |
