Model A- where to mount the pedals? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 04:28 PM
31ROC's Avatar
Gonna be switching to a 4-speed, dont think there's much room under the floor for pedal mounting, and dont really like having clutch & brake reservoirs mounted outside on the firewall.....so I am left with finding a spot under the dash, have not looked yet, should there be some sort of brace under there to mount these?
('31 Model A Coupe hot rod)
Old 11-27-2012, 06:00 PM
Dennis W. Parks
Pedals
Most likely, you will not have an adequate brace under the dash unless you install one. I believe you could build one easily enough by bending some tubing (one to two inch diameter) to closely match the shape of the inside of the cowl. Weld a flange on each end so that it can be bolted to the floor/frame rails. You can then mount your pedals and have something substantial to mount your steering column to as well.
Dennis W. Parks
Author of automotive how-to books
Old 11-27-2012, 06:14 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
I used a frame mount brake pedal from TCI on my Model A. I have also contemplated a 4-speed swap, they have a dual mount for use with a hydraulic clutch, see page 38 of their catalog http://www.totalcostinvolved.com/pdf...Catalog_22.pdf
Name:	TCI Pedal Set-up.jpg
Old 11-27-2012, 06:18 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Dennis W. Parks
On my T, I used a brace made of 1 1/2" x 0.120" wall square tubing, like an upside-down "U" and welded it to the frame. Stiff as a minister's dick and worked well.
Old 11-27-2012, 06:35 PM
31ROC's Avatar
yup...just took a peek under the dash.....nothing there, column is supported by a bracket welded to top of the cowl, pretty sturdy there, but nothing for pedals to be mounted to.....man I hope I'm not STUCK with this A/T!
Old 11-27-2012, 06:39 PM
31ROC's Avatar
Originally Posted by lakeroadster View Post
I used a frame mount brake pedal from TCI on my Model A See page 38 of their catalog http://www.totalcostinvolved.com/pdf...Catalog_22.pdf
nice looking package kit, but after looking under my floor, I dont see how that fits under there and pedals fit between the steering column too....
Old 11-27-2012, 06:42 PM
Yeah, it's tighter than a tick. What type of steering box are you using?
Old 11-27-2012, 06:45 PM
31ROC's Avatar
unisteer rack & pinion?
Old 11-27-2012, 06:47 PM
And your current brake pedal mount / master cylinder is under the floor?
Old 11-27-2012, 06:50 PM
31ROC's Avatar
And your current brake pedal / master cylinder is under the floor?
yes, its mounted to the frame, manual brakes, the pedal comes up through the floor practically underneath the steering column, a bit off to the right side, I dont see how a clutch pedal can fit on the left side of the column?
Old 11-27-2012, 07:01 PM
The pedal arms can easily be heated and bent to position them where you need them.
Also keep in mind that your 4 speed will take up less width than the automatic.
Are you running under the floor exhaust?
Old 11-27-2012, 07:05 PM
31ROC's Avatar
this is true...but the tranny's not the issue, its the lack of room between the frame and the steering column for the clutch pedal arm....
I am running Patriot outside headers/sidepipes, nothing underneath
Old 11-27-2012, 07:09 PM
That's the tuff part of doing this after the fact. During fabrication moving the column toward the center a little is no big shake. Doing it now pretty much sucks.
It's easy for me to say, but I think you can make this work. Did you look closely at the TCI photo above? The clutch pedal hugs the frame.
Got any photo's of your current set-up?
Old 11-27-2012, 07:12 PM
31ROC's Avatar
yes I did...wish I had one to mock up or test fit, wonder if they'd lend one to me for that purpose? or buy one and be able to return? guess I'll call them tomorrow....thanks for all your input, maybe I;ll try figuring out how to post pics tomorrow to see if that helps anyone to see my delemma!
Old 11-27-2012, 07:20 PM
Irelands child's Avatar
I have a reinforcing framework around the entire pass. compartment in my '31. Lots of 3/4 and 1" tubing, both round and square. There is not a bit of the dreaded Model A cowl shake or body flopping
You do run into a problem with a steering column - too low, no room for 3 pedals. Raise it higher, then exhaust manifolds get in the way and you can end up with more then three U-joints and an additional support bearing.
Dave W
Model A headlight custom mount Fastsx321 Body - Exterior 1 03-29-2011 12:13 AM
which pedals project34 Hotrodding Basics 1 04-18-2008 02:17 PM
pedals Hot Rod Mike General Rodding Tech 4 03-24-2008 08:06 PM
pedals pulsates Augusto Transmission - Rearend 4 05-16-2007 08:06 AM
pedals solowookie Suspension - Brakes - Steering 4 04-10-2002 06:13 PM
