Which modern engine easiest swap? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 10-13-2013, 11:24 AM
murrsue's Avatar
Last journal entry: 57 pickup 8.8 rear axle install
Okay I'm in the planning stages of a budget build 63 Ford pickup. I'm going to put IFS in. I've built a few rods over the years. My last project was a 57 Chev pickup that I put a Volare clip in, a 350/overdrive automatic with 8.8 rear. Anyway I'm leaning toward a modern EFI type engine even though the wiring/computer stuff is going to be a challenge. This is going to be a street driver, no racing. If I got near 300hp that would be perfect. Being a budget build I will look for a good used donor and wrecker stuff as much as possible. I'm also leaning toward a 5sp standard this time.
Here's the question. What modern engine might be easiest for my project?
murray
Old 10-13-2013, 12:19 PM
easy transplant
i would say 5ltr ford with a 5speed manual, have don several last being a53 f100,get1 out of a mustang and you will have the headers,dit at the front etce.good luck cliff
Old 10-19-2013, 07:02 AM
Another engine to look at: The Mustang GT 4.6 liter was in production from 2005-2010, and they are rated at 300 hp (there are also a few rated at 325-330). I don't know how well the engine would fit in your truck, but its a very smooth, good mileage drivetrain in the Mustang. They have been out for 8+ years, so I'm sure there are quite a few in the junkyard by now. The new 5.0 liter Ford coyote engine is even better, but I doubt you could find one for a good price.
If you went with an automatic it would probably be easier, but its a hydraulic clutch so the linkage should not be that bad to fabricate.
Bruce
Old 10-20-2013, 07:21 AM
Any of the GM EFI engines are abiout all teh same as they all require the same wiring. 96-02 Vortec 350 will give you about 300hp grossm stock ls1 about 370 gross.
All these use a bout 58 psi of fuel pressure.
peace
Hog
Recent Modern Electronic Engines posts with photos
Best, easiest way to support engine for bellhousing alignment? v8hed Transmission - Rearend 10 03-06-2011 07:02 AM
Easiest transmission swap? Gearstix Transmission - Rearend 8 01-02-2009 08:48 PM
Easiest 57 Chevy wagon RR end swap. eyesore 1 Transmission - Rearend 4 07-11-2008 05:18 AM
Using an 30's rad with a modern engine? 427v8 Engine 18 04-28-2008 05:41 PM
modern engine new probs wulf Engine 17 01-08-2008 04:47 AM
