modern gas tank floater assembly with old dashboard? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2009, 08:01 PM
When putting EFI in my '57 Chevy Suburban, I want to use the complete in-tank fuel pump/pick-up/floater assembly from a late '80s truck (the same that supplied some EFI parts) in my stock tank. I know I will have to modify a bit!
My question is whether the '80s floater part in the tank will work with the '57 gas gauge in the dashboard? They may not require the same resistance...
If they would not work together for electrical reasons, how can fix this, how can I modify to make them work?
I want to do this because I like to have more modern parts when I can for ease of maintenance/reliability.
Thanks!
Old 11-25-2009, 08:26 PM
Cape Cod Bob's Avatar
They need to be of the same resistance, The oold guage is probably 30 ohms. You will have to modift the tank resistor to match if it does not measure the same as the gauge.
Old 11-26-2009, 06:05 PM
Anyone knows the resistance of the late '80s truck floater assembly and if they are not the same resistance, is there a way to "correct" the resistance, something to mount between tank and gauge, maybe?
Old 11-28-2009, 09:57 AM
"GM Fuel sending unit conversion 30 ohm" is a post by Eric64 that docvette answered in 2007.
I'm a computer doofus, so I can't do the hyperlink thing— if you do, tell me how! Look up that post and you'll be educated. Cheers!
Old 11-28-2009, 02:04 PM
Here's a link to that post.
Old 12-03-2009, 01:24 PM
fast68's Avatar
likes chevy trucks & boobies
i thought gm was 0 to 90 ohms range
Old 12-03-2009, 01:37 PM
ogre's Avatar
the 'Duracell Project'
new is 90, old is 30.
good catch marzini.
Diesel pumped in new Corolla Gas tank michael2 Engine 21 05-05-2008 11:29 AM
Camaro 70-73 gas tank question kdj997 Body - Exterior 1 02-20-2008 11:21 AM
Gas Tank 1970 Chevy Camero kan Engine 0 05-21-2006 11:57 AM
welding on a used gas tank mychevystang Garage - Tools 5 10-10-2004 09:33 PM
gas tank pressuring up montea General Rodding Tech 3 06-04-2004 08:37 PM
