Modern seat construction - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2007, 07:31 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Here are some pictures of how the manufacturers are assembling seats now days. The first picture shows a product called Velstick that is a hard plastic version of the hook side of Velcro attached in grooves to the foam on the seat, and a loose piece. I buy it in 4 foot sections.
The second picture shows the orange yarn sewed onto the seams that mates with the Velstick. The third picture shows the gauze tape that I use to replace the orange yarn. There are other versions of the loop side of velcro that can be used to mate with the Velstick. the last picture is the finished seat. This technology replaces the wires in listings that were hog ringed on. Wires in listings are still used by some manufacturers. I saw one seat recently that had springs attached to the wires that were attached to the seat springs. This new technology sure makes it easy to assemble a seat.
ID:	22166   Click image for larger version
ID:	22167   Click image for larger version
ID:	22168   Click image for larger version
Old 06-20-2007, 07:38 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Not surprised. Like everything else on late model cars, there is nothing there of substance. Gauges, body parts, suspension parts, etc., these things are so integrated when you try to salvage a component for hot rod use, there is nothing there.
Old 06-20-2007, 01:34 PM
Wiki Edits: 22
I agree with you about all of that, but actually, the seat construction now days is very good. Everything under the fabric is very well constructed. This seat came out of the rear of an Olds Aurora, and would make a great seat in a hot rod.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
68 firebird to camaro rear seat 68birdman Interior 24 11-23-2007 11:07 PM
Power Seat Wiring Info Needed- Mid 70's Chevrolet/Chevelle LongTom Electrical 1 02-06-2007 01:36 PM
Can not figure out how to remove rear seat. HotRodMan Interior 7 04-26-2004 07:27 PM
New Seat Vendor for 48 Chevy Truck??? bg Interior 1 08-28-2003 08:12 AM
