Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Modern wiring in '40 Ford
Old 08-18-2012, 05:54 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Can we "assume" that the attached photo is the switch/lock/column drop that you intend on using? I too am of the opinion that the switch should be used only on the ignition only through a relay, keeping the Ron Francis supplied 'universal' switch as your main ignition switch and hidden from sight which is what I think you are trying to do. I'm not a real lover of those original dinky keys and steering lock switches, having in my dark past broken keys or had a couple others just wear out - but, of course, that's my opinion only They do look fine in the right period car (you ARE replacing that cotton covered wire to the switch, aren't you?)
Irelands child
